back on the stabs...
I have cut out the elevators, and now, time to add the LE & TE of the hinge line, and then the hard point.
I have made the hard points, using the plywood from the Carden kit. Very high quality and very dense ply.
I made two slots in each one for the G10 horns.
this is what it should look line once the hard point is glued in and the horn is installed.
The TE on the stab, and after it has been bevelled.
the stab, being aligned, from the tips. the LE is not on the elevator yet.
I have marked a point, 16" in from the tip of the elevator, and this is the center of the hard point for the control horn.
so in goes the hard point.
after this, then I can glue on the LE of the elevator.
