Boo-hoo! I crashed my Laser!!! And in the stupidest possible way! I was practicing slow rolls trying to keep them as crisp as possible. Of course I forgot to set the timer and the LVC kicked in when I was in the KE-portion of a slow roll. Tried to roll it back upright, but that bled off too much speed and put me in an unrecoverable (at least without power) spin. It smacked straight in from 20 ft and did a few cartwheels in the weeds at GCA. I though for sure there was going to be pieces all over the place. But the plane was actually in one piece. Unfortunately, there was a lot of internal structural damage:
* Cracked longerons
* Former at the back of the canopy cracked.
* "Cross-bars" (I'm sure there's a fancier word for it) on motor box cracked.
* Plywood reinforcements where the wings attach cracked.
* Cowl chipped and gel coat missing.
* Broken prop.
* Possibly bent prop adapter on the Motrolfly 2820.
I think I know how to fix it. Instead of trying to patch the motor box, I'm just going to remove the cross-thingies (what the heck are they called???) and stiffen it with CF rods. I may do the same with the former and glue it back along the side of the fuse and add a CF strip to replace the part going across the fuse. That should be as strong, if not stronger than original.
Any pointers?
