Spats
We can cut some for you for you of what I did for Dave. Would you like some for the rest of the plane too? I just need some dims that you could easily supply for me. Here is the pic of the ones I just made for my 125" MXS project. I just put two holes per horn so that the inner holes work for the tail surfaces an inboard aileron servos an the outside hole will be for the outer aileron. Obviously there is a base plate that joints the horns ala arf style. I also make rudder tiller horns in any width you may need.
If you ever want horns All I need is the dimension from the center of the mounting block to the center of the hinge line (reach) an from the mounting surface to the holes (height). They are CNC cut so I can get down to the gnats ass.
Thanks Terry,
I am going to put together some sizes. Does the new PAU Viper come with these or are they the control horn bolts from 1984?
