The pull/pull rudder was actually pretty easy. I...
1) took the dremel and chamfer'd a couple of ball joints real quick like to save some wear and tear on the cables.
2) I used some throw away cheap steel pushrods and the chamfer'd ball joints to make cheap easy "tensioners"
3) I cut off the end of the stock control horns on the rudder down to the middle hole. That left me with a 9/16" offset behind the rudder hinge line, but now plenty of throw/travel.
4) I broke out some of the eyelet plywood in the fuse that was in the way of the cables.
5) I did a Mickey and Jerry (Micky Mouse, Jerry Rig) rudder servo offset control arm that had a 9/16" offset behind the servo output shaft. The servo arm is 4", so is the distance across the rudder control horn holes I'm using (the middle holes).
6) I picked up some 160-lb test stainless steel cable. I wanted some 220 but they were out of stock. What do you guys think? I picked up some "double" copper sleeves to crimp on, too. I used two crimps per connection.
So, nice geometry, nice working action. The non pulling cable does not get tighter nor looser throughout the range of travel.
If anyone wants to go pull/pull rudder on this plane, and wants a super fast and easy time of it... with full travel... just get one of these:
http://www.aircraftinternational.co.../RtnTab/133/PageIndex/1/CatID/54/Default.aspx
I've used a bunch of them (even putting them on bushing bellcrank setups) and they would work perfect here... possibly even slightly better than what I did because of the thickness of the rudder.
If I had known what the situation was with this ARF I would have had one of these ready and been done in a few minutes with tons of throw and good geometry. I just thought, 2015, it's going to be plug and play.
