Matt Goethe
30cc
How does this plane compare to the Aerobees Extra you did the build and review on earlier in the year?
got a few pretty shots of mine today!
Had to adjust the thrust a bit and give it a touch of UP thrust and now it's REALLY smoothed out!!! VERY VERY fun plane! END over END waterfalls at high speed. Does insane knife edge spins
View attachment 29402View attachment 29403View attachment 29404View attachment 29405View attachment 29406View attachment 29407
Video!
[video=youtube_share;f8U3Q78tJ8k]http://youtu.be/f8U3Q78tJ8k[/video]
I rarely watch 10 minute flight videos from start to finish. That was great. Still researching my options but this plane is rocketing to the top of my list.
Couple of questions. I know this plane is a little heavier than the Aerobees Extra so how do you think the Redwing Extra will perform with the DLE 30CC vs the 35CC? Also, did you have any trouble getting the CG right? And finally what drove you to change the thrust angle mentioned in a previous post?
Thanks
how much up thrust did you have to add. and how did you ad it.?
thanks
Where's a video of you flying it? Sounds amazing with that DA35 in it and wow she looks beautiful!
I think it'll fly fine with a well tuned DLE30. You may need to add a few ounces of weight, or use a nice Pitts muffler (I am).
That was literally the second flight on the DA and the power to weight was very nice!
The up thrust was an experiment by myself and Tim at redwing to improve performance on the plane. Redwing is in the process of issuing a service bulletin and instructions, but the short version is adding 2 degrees of up thrust really makes the plane fly even better than the original design.
To do it, add 3 small washers on the bottom motor mounts where they meet the firewall. You may need to also shim the cowl to match.
I'll be adding a few more washers to mine (I've only got one on each side right now) and will take some photos of what I do.
So as you saw in the video, it flies fine with only a small improvement on the thrust angle, I'll get another vid as soon as the work is done.
It isn't anywhere, there isn't one. give people and inch and they want a foot, jeeez
Yeah, the da35 is sweet
I was VERY impressed with the power and smooth responsiveness of the engine... Another plus was I didn't have to adjust the needles at all. Just bolt on and go shred the sky!
