Check the throw in both directions and make sure it's equal. Then peg the ailerons hard one way and push on them a little bit; try to push them back toward center and observe how they behave. Peg the ailerons in the other direction and push on them again and compare.
More than likely it's just the motor torque though.
Did you smear Welder glue on the hinges to reinforce them when you built it? It's easy to make them too stiff when doing that. If so, cut them free, then re-hinge with Welder glue and some Blenderm tape.
