YA! I bought some of those. They are real nice in person too. I missed out on the cool rudder horn for the steering tho
Crap, I know I was switching over to the black material and maybe did not have those set up yet. I'll drop one in the mail for you but won't be back til Monday. I still have your address.
- So for the control horns there are seven sets for four ailerons, two elevators and one rudder. The Viper is designed to balance and work well with a single rudder servo.....especially on a plane this size. A single 7950, Savox 1270 or Savox 1230 works very nice. If you should build one and want dual servos, I can always send off another couple for the other side. The fuse has been structurally braced to also handle the torque of a single servo, and has proven to hold up well.
- There are three sizes of the horns. The longest ones go on the rudder, the middle ones go on the elevators and OUTSIDE ailerons and the shortest ones go on the INSIDE ailerons. They are calculated so that they need very little balancing on the ailerons, but please don't forget to balance them.
- The boxes are simple and I will illustrate those getting installed in a week or two. They are simply glued into the surfaces with quite gorilla glue (the quick stuff), then sanded flush and hinge stock is installed AFTER that. Once the hinge stock is installed the blocks get hardened with thin
FOAM SAFE CA glue. Once everything is covered the horns are installed with epoxy just like you would on an ARF.
