Aerobeez 64" 20% Scale Electric Conversion MXS-R At Joe Nall 2015
Bushwacker
3DRCF Moderator
Yes Sir I do. ABZ4581 and thank you very very much for this.
You guys ROCK!!!!!!!!! Told you I would be a return customer after all you guys did for me last time. :)
Aerobeez
No need to thank us. We are just doing our job.
Thank you for the support.
Customer service is a key to our business. We try and give everyone 110% when we have issues with our products. This way we get important feedback and improve upon our service and products.
Ps. The Banshee is Coming !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Bushwacker
3DRCF Moderator
oh dat sounds fast and mean. Any pics or vid?
And of course I would thank you dude, don't mind expressing my appreciation at all. Job or not. :peace:
Aerobeez
Let us check together! Your MXS-R will be going out today. Opened up the box, checked the cowl, wheel pants, fuse and wings. Everything looks in order. It' on the way !
We will release pictures of the Banshee Project very soon. Have any idea what it might be?
Bushwacker
3DRCF Moderator
OMFG! :megaroll:
You said it Bloosee... WoW guys I was just expecting a note saying it all looks good. All I can say is "Just Freaking Awesome"
My next purchase from you guys will be that Killer 93" 32% Extra 330SC :lovestruck:. I still need to figure out what motor to put in it though. I run electric only so there is my dilema. Motor would probably be a Hacker Q80-8M. You guys think an A100 would work or be to much?
Thank you again. :)
Aerobeez
One of our field representatives in Florida has a electric 93" Extra. He's running Rimefire 65cc, ZTW Gecko 150amp opto ESC on 12s. Here is a video.
https://www.facebook.com/gerald.hippleii/videos/o.221509561245369/996253530399894/?type=2&theater
OMFG! :megaroll:
Thank you again. :)
Bushwacker
3DRCF Moderator
So I need a bit of education. I don't know anything about the Rimfire motors. Say's it's 160Kv, 8400W. What Hacker motor would I compare it to? Nearest match.
Bloosee
Just look up the Rimfire motors at Tower Hobby, they are good motors. A guy at our club it running a Rimfire 50cc equivalent motor in his Redwing 89" MXS, it pulls like a freight train and sounds awesome.
Bushwacker
3DRCF Moderator
Well I sorta did that, I went to Espritmodle.com and found it HERE Gave me the specs below.
Price: $275.00
RimFire Outrunner Series
80-85-160
Kv (rpm/V)160
Max Power (W)8400W
Max Amp (15sec)150A
Max Efficiency83%
Io (No load A)-A
Rm (Resistance)-Ohm
Shaft Diameter10mm
GearboxN/A
Motor Diameter80mm
Motor Length97.3mm
Motor Weight1480g
Built in FanYes
Max Rpm10,000
Poles-
CaseOutrunner
ESC Timing22 deg
ESC Switching Freq.8KHz
Hackers nearest match I think is THIS same site.
Price: $905.00
A150 Outrunner Series
A150-8
Kv (rpm/V)166
Max Power (W)9000W
Max Amp (15sec)190A
Max Efficiency91%
Io (No load A)3.6A
Rm (Resistance)0.015Ohm
Shaft Diameter10mm
GearboxN/A
Motor Diameter109mm
Motor Length114mm
Motor Weight2100g
Built in FanYes
Max Rpm8,000
Poles20
CaseOutrunner
ESC Timing22 deg
Model TypeModel NameMotorControllerBatteryProp
Scale 45 lbs./20kgP-51D MustangA150-8Jeti Spin Pro 300TP6600 12S Li-poly26x15 XOAR
Aerobatic 100-120ccUltimate Bipe 2.2A150-8Jeti Spin Pro 300TP6600 12S Li-poly27x12 XOAR
Pretty interesting stuff.
