-= SLiCKNeSS SiCKNeSS =-
wedoitall
Member
Glaciers 4s2200 30C
15x6--67.8amp @ 969 watts
14x7--57.85amps @ 800 watts
same on the 15x6, really sucks the juice out of the lipos at full throttle.
wedoitall
Member
the Align seems pretty awesome on static runs. throttle response pretty freakin awesome. only thing is most of the power is half throttle and above. whats the best way to use a throttle curve to fix that.
not that many options on settings on the Align I have timing set to high and throttle response set to quick speed
Not sure on the high timing, it may not be necessary, but I'm not sure.
For the lipos, the 2200 are just too small for this power plant. I'd do 2600 at least.
If you can get a LiPo that handles the 15x6 prop, you'll like it, that was my favorite prop.
As for the curve, try 0, 35, 65, 80, 100
wedoitall
Member
I tried medium timing and at startup there was a slight whining weezing motor sound. I didn't try LOW. also on the props the 14x7 was a Xoar and the 15x6 was an APC. gonna try to get some 3300 or something closer.
wedoitall
Member
also on the elevator whats the max deflection are you guys getting? I could only get about 45 degrees. im kinda use to getting at least 65 degrees
