Enterprise
I left mine off and the pants. I fly basically only off grass but I agree the cuffs look nice. They are going onto the 74 laser for sure.
Left off the LG covers. I ground down every washer, and turned down socket head cap screws on the motor mount. Turned down the DA stand offs a little. and since I am using the Tech Aero Ibec, I lost a battery (only use two). Also chose nice slim 2S life packs that are light compared to others I own. I was careful to get servo leads that are the exact length. I used spyderwire instead of heat shrink on the servo lead connections as keepers. I built my own Gas tank (super light weight). Basically I was mindful of every aspect of the build to make sure the weight was kept to the minimum. 5 oz that seems like a big difference, but I guess all the little stuff adds up.
So the 50r us a little heavier than the da50, nice to have the extra power.
Aeroplayin.......I do not remove the covering at the crimp. I feel that it is lighter than steel cable but Have never weighed either. Originally I used Kevlar to work on a glitching problem back in the 72 MHz days. Also less worry with this product about the abrasive nature of Kevlar rubbing on the other line or at the fuse exit. I use the .058 on anything gas powered.
Richard
Since the stand offs are part of the engine, and the Pitts specifically related to the engine is also light, the AUW is really lighter than the DA50. Here are the size specs.
The other thing I like about it is that the nose is longer, placing the engine further back in the cowl, so there's a lot less cutting. It's a rear exhaust mount too so everything fits in a nice clean, narrow line, front to back. We ended up running Royal Purple in it and dropped the temp and raised the RPMs on it. Feels like I'm talking myself into another one, but I haven't gotten any emails back from the new US distributor so I may dig out the company contact info I have around here somewhere. Here's a pic...View attachment 31029
