Can you print over the existing tail wheel bracket and just extend the two arms for a bigger wheel.
It would be too narrow.
Wow nick 2 inch arm and the lowest hole will take away a lot of torque from the servo, and those ailerons look pretty big. Will need some pretty good servos to do the job.
Gentlemen received my Timber 110 at last. Went through the box everything looks good and the windscreen is ok.
Before I start I need to make up my mind how it will be powered. At first it was going to be done electrically. But I am having some doubts. The planes estimated weight could be 19 lbs or more which I think will be to much for the electric motor which is 2000 watts. Have been looking into getting a DA 60 for the plane, boy they are getting expensive, quality is always costly.
What have you read and how good is the performance. Thanks for posting.AWESOME!!ITS ABOUT TIME!!!!
Always glad to hear it survived the transit!
There have been quite a few used DA50's getting posted on FG... Just a thought....
There’s a good deal on a DA 60 on that other site. I think it was $400.Gentlemen received my Timber 110 at last. Went through the box everything looks good and the windscreen is ok.
