I like to use servo screws so you can use a ball driver.
So, what do you like better... 130lb test that is coated or 250lb test that is not coated?
These the ones you like @Terryscustom ?![]()
Yeah, the first time you have to remove a bolt that's cinched down on a Nordlock washer, you're going to think you broke something. That's because they don't simply loosen. You have to overcome the tension of the teeth and you will hear and feel it pop loose.Yup, welcome to never loosening mufflers and prop bolts!
I run the screw through the clamp in the cutouts.Hey @Jetpainter , I use flat head screws and countersink them... then put the clamp over them so they can never work their way out. How are you doing the servo screws, I imagine they're holding up fine, yeah?
That's exactly what I do.I run the screw through the clamp in the cutouts.
Check out the mystery dents in the front of the can in the one pic. I have no idea where they came from.
View attachment 44889 View attachment 44890
