Video! that only took 30hours to process in 2.7k.... enjoy!
Great flying and great video really enjoyed it watched it twice and probably a few more times. The large front wheel do good job but there were a few shots of the Tailwheel really taking a beating. Thanks for doing that.Video! that only took 30hours to process in 2.7k.... enjoy!
If my memory serves me you got the Tailwheel with three leafs and I got as many others only two leafs on the Tailwheel, that’s good you really need the three.Thanks guys! @WMcNabb Enough time to grind your beans, boil water, French press, and enjoy a full cup LOL!
@Snoopy1 Thank you! I've watched it so many times editing I was starting to get numb! But YES, that little wheel is getting a whoopin! I'm surprised the plastic hasn't broken, and the rudder hasn't had any impact damage from the wheel.... and that the OEM spring is still good - I've bent it back a couple times. It's just mesmerizing to see that 8.75" tire conforming to it's surroundings.
@-Rick- THANKS!
speaking of tailwheels, I have not acted yet, (waiting to see if I need tail weight or the CG point) But Ohio Superstars makes an unbreakable unbendable 1/3 scale unit including a 2 7/8" wheel, spring steel leaf springs, 6061 T6 casters, ball bearing, weighs 5 3/4 oz, has anyone weighed the stock gear? I don't have a scale. The holes don't line up, but he is willing to drill a hole for me before he tempers the steel because afterwards it would be nearly impossible with normal drill bits. I used to use his products exclusively on my 120cc 30 pound towplanes and never had a failure, bullet proof. Interestingly although a different layout the over all length and height are almost identical to the stock gear. 80 bucks. Note the clamp on the springs is just a keeper for shipping, there is a bolt hole there.
View attachment 117900 View attachment 117901
