Scale 20cc DHC-2 "Beaver" Kit Build from Moustache Model Works
Finally reached a point in the build where I felt it was time to install the engine!
Used a nylon clevis and a ball link for the choke.
throttle arm was from stuff I had lying around with 2mm ball links. VVRC extended throttle carb arm.
Put a piece of Viton fuel tubing on.
then with a dab of locktite, put the engine on wit the supplied bolts
mounted the ignition module with dubro foam and velcro.
Got the throttle linkage on. Note a dab of medium CA on the nut.
Put the fuel tank in. Using a 8oz V2 fortitude tank. Not quite sure where my fill line will go, so I just coiled it up for now.
Trimming the cowl up with the DLE20. Nothing too exciting here, made a nice cutout for the plug and marked where the cap rubs. If I secure the ignition lead off to the side I don’t have to cut anything. Not quite sure which way I want to go.
29307242-B1FA-4AF8-A238-F47390BB6372.jpeg 9EB7C4DB-3CE2-475D-8219-41A6B33DF530.jpeg 33D1860E-C2FB-477E-A6B0-E4258B6EF43B.jpeg
