Tseres
Been recuperating from Jet lag. Not quite there yet. The weather turned cold for the next few days. Yesterday never got to 50F and the wind was blowing 22mph and gusting to 30. That's cold and miserable for this time of year.I decided to start cleaning up the bench for the Camel build. You guys already know that I hate cleaning up so my bench gets progressively more cluttered as time goes on. It took a while to get it done. I double checked the surface for flat. Had one high spot that was easy to fix with a screw tightened just enough to get things flat again.
The reason I got started yesterday was cause I finally got a Facebook account. I mentioned that I didn't know what I was going to do with it. Then Bunky mentioned that it could be a waste of time. He had a point there so I went out in the shop and started cleaning up.. Until the weather gets back to flying weather again, I'm going to start building the top wing.. I'm still going to be on Facebook. Just not as much.
I actually read the first part of the directions.
In there they mentioned that the top wing is going to be built in one piece. Had to check the length of the building table to see how it would fit. As it turned out, the wing fits without the wing tips. That means I can build the wing and move the plans to build the wing tips. Started marking the die cut parts with the part numbers. In this build the directions say to not take the ribs out of the sheet until you need them. Thats a great idea since I had a hard time finding the right ribs for the Fokker build. This was a lesson I learned that I was going to use anyway.
Thats as far as I got last night but that's a start.
