I'll keep you in mind Snoop.
First job for the rotary table. Had to elongate the prop bolt holes in the back plate, was drilled on a 28 mm bolt circle, the Roto 85 are on 32 mm bolt circle. Turned a piece of steel to fit the back plate center hole, was .395", then drilled and reamed to 1/4" diameter and pushed a 1/4" pin in to fit the hole in the table. It ran out at .003", was OK with that.
