Hello all!! This bird now has over 80 flights on her, and she is flying super nice!
I love this airplane, and probably (no, correction, it is ) the best flying airplane i have ever owned.
I must admit, if you look thru the thread, I did not pay much care or attention to the tail wheel steering mechanism, and this was probably due to the fact, that I was so close to being finished, I cut corners.
This is a J & J tailwheel, and what I have had to do, is to remove the prior steering arm, which was screwed into the balsa at the bottom of the rudder. HA HA, i should have known better this would not last long. Believe it or not, it has lasted for over 80 flights, but i have noticed it was starting to come loose, slightly. Amazing how screws can get purchase in foam!!
Ok, this is not a solid construct.
The pictures now show, i have removed the G10 material arms, and now I have cut out a rhomboid shaped area on the front end of the bottom section of the rudder, approximately 1/4" thick, and then obtained a 1/4" plywood block, drilled three holes thru them, and then used blind nuts on the back side.
This is now glued in. Tomorrow, should be cured. I will remove the arm and three screws, then cover the area with black Monokote.
Here is my question, and before I get to that, i am using these mock cables, to let me see the travel. These wires you see will not be the ones I will use.
My question:
Should I go with a holes closer in on the arms?
and, anyone have any advice on what i can use between the compression spring and the hole of the steering arm. I do not like the idea of silicon tubing with zip ties.
If possible, please post pictures of your J&J tailwheel and how it is set up.
Thank you
