jamesrxx951
Just got the power plant, and was working on installing the canisters. The fuselage is ready to be sheeted, except, I am waiting for Fuselage Side Support before I proceed with that step. Also for the landing gear. Once I get those two in, then I will be able to sheet the fuselage sides and then glue on the fin.
I always weigh the motor. This one says 10 pounds and 2 ounces. Could be that the scale is off, it is advertised to weigh 9 pounds and 15 ounces. I will re-weigh her again this evening on a different scale. Or, it could be that the weight advertised is with no sensor and no spark plugs. Does not matter!
I like to wrap the flex section with this silicon tape, it is rated to 500 degrees F.
I am using the comfort mounts, from KS, and the canisters are the KS 95 rear dump, with the 70 degrees bent stinger.
Cam, that picture soes not look like it is the L version of the 200. It looks like the standard. It seems pretty lite for the standard though.
