Sounds like my king of plane! With that said, I think the number is anything past 38 degrees on the ailerons acts as airbrakes, but that's what experimentation with the prototypes are for!
Here is a the side and top view of my final design. I couldn't bring myself to put up the original blueprint with all the measurements so I traced it and colored in the key areas.
I agree to an extent that too much hurts regular flight performance. If one prefers much less throw, just set it up with less throws, that is an easy fix. However in post stall, or extreme 3D radical throws can be a benefit. Crankshafts like a ton of throw for example. Remember this is not an IMAC place that does 3D, this is a 3D first plane, that does IMAC.
IMO, its way better to be able to achieve ridiculous throws if you want them, then want them and not be able to achieve them. Lastly, this ain't no Katana, look at that wing, it's way way different. I studied so may airfoils and designs of so many aerobatic planes, this is what I came up with. This is the wing I will test and try to develop.
Like I said before, this has been a long time coming, hundreds of hours of effort to get to this stage, and we still have a long way to go. The fuselage shape Incorporates no less that 20 design elements that I felt need to be implemented. Just looking at it, it might not look like much, but I cant wait to fly it.
I cant tell you how good it feels to have a vision, then develop it, partnering with many friends picking their brains along the way. Then to see it finally become a reality, it feels so good, and I am just getting started.
Couldnt agree with you more! One more thing, for the 65 inch version, what size servo are the slots designed for? Right now im kinda dissappointed that i bought a 57, because im spending way too much money on servos(couldve had perfectly set up 30cc for the same price), most micros(or is it minis, always get them mixed up) just cant take the abuse that the airframe is more than capable of. Would be nice to have standard servos, where there are more options and more grunt. Just my two sents thoughHere is a the side and top view of my final design. I couldn't bring myself to put up the original blueprint with all the measurements so I traced it and colored in the key areas.
With that much elevator to stab ratio, are you worried about flutter at high speed?
To keep the weight down Mini servos are what it will use most likely. They are spend-y, Heck the MKS ones I used in my 64" MXS were $105 each.Couldnt agree with you more! One more thing, for the 65 inch version, what size servo are the slots designed for? Right now im kinda dissappointed that i bought a 57, because im spending way too much money on servos(couldve had perfectly set up 30cc for the same price), most micros(or is it minis, always get them mixed up) just cant take the abuse that the airframe is more than capable of. Would be nice to have standard servos, where there are more options and more grunt. Just my two sents though![]()
