The filter is an Oregon 30-301 (for Techumse small engine) available at Walmart / Home Depot / Hardware etc..Couple of bucks.
To adapt it to the velocity stack I cut the rubber bulb from a Danco flapper and secured it to the filter with a nylon wire tie. I did trim the outer portion of the rubber cap on one end of the filter for a better fit to the flapper bulb.
I made the filter end plug/support from a gas fuel bung stopper.
View attachment 100297 View attachment 100298 View attachment 100299
I don't believe it will affect performance unless it becomes very dirty / fuel soaked. It should make the engine super quiet with the canister. I will give a video report once it is in operation.
Thanks for that, nice setup now if only I can remember where the info is when I need it thanks for that.
