Are they going to fly fast?
Yup and they will fly out as far as you can see and high enough to get into trouble. Darn noobs
The weight is awesome! I noticed a little micro balloons on one of your posts about the engine box, is that a helpful gap filler, or were you using that as a strengthener? I tried to find the post in a hurry, but didn't see anything about it. I apologize in advance if I missed it.![]()
No Problem Tyler. You are probably referring to the following posts:
Viper-ST 100-120cc scratch build......it continues!
Since I did this build with medium CA I used the following process:
- Apply glue and clamp parts.
- After set for a few minutes I chased the joints on both sides with medium and let soak in. Small amount of kicker only as needed.
- In areas where stress will be present I applied microballoons to the second step above right after applying glue. This forms a fillet and makes the joints VERY strong. With a couple of test parts it proved to be slightly stronger than wood glue joints.
Is Briallent a word? CA and microballoons is brilliant however. Love watching your builds Terry.so... you applied microballoons to the wet medium CA ?? Briallent !!
I thought I should make a stupid post to show I am back. Everything is looking great Terry and Rick, I can't wait for these to hit the market.
Thanks Terry, good to know! Thanks for also including all the tricks an tips on your posts!
Kind of ironic that you misspelled brilliant.Today... you are dead to me...![]()
